RCD Testing | on ElectriciansForums
Discuss RCD Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J.C.E
Earth
What do you have to test when your testing rcd?
Just record 1x and 5x? and for nonsence tripping at 0.5x (which it shouldn't trip)
And I have looked in regs, but can't seem to find a table for maximum reading? But I quickly looked in the OSG and it says should trip within 200ms for 1x and within 40ms for 5x ..... is this correct and all I need to test for with the RCD? Plus record on the forms what amp and mA rating it is..
An RCD test should consist of 6 seperate tests, @ 0.5 x IdeltaN, 1 x IdeltaN & 5 x Idelta N (5 x only applicable if it's a 30mA rated RCD for additional protection), on both sides of the sine wave (0 & 180 degrees)
As you said, the 1 x & 5 x values are recorded on the certificate together with the characteristics.
Old BS type RCD's were required to operate in 200ms @ 1 x IdeltaN, the newer BS EN types are required to operate within 300ms.
Reply to RCD Testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It can also mean lasts or continues for two years.
Ok I’ll try this when I’m down
