RCD tripped by central heating which is on a separate circuit | on ElectriciansForums
Discuss RCD tripped by central heating which is on a separate circuit in the UK Electrical Forum area at ElectriciansForums.net
L.F.
My central heating is on a dedicated RCBO. The house has two other RCDs, one including the fridge, freezer and cooker. The other RCD is tripping virtually every day after the central heating has been on for 40 minutes or so. It will then often trip again after a few minutes. It can be reset and then it won't trip again until the next day. However, if I let the house temperature drop it will trip again once the central heating has been on for 40 minutes or so. It doesn't trip in the summer. It's driving me mad. Any ideas please?
wild gues. could be cable/s (maybe with damaged insuluation) touching a hot pipe. when the pipe heats up from the c/h, the fault appears
Thanks, that has been suggested before. It does seem to be linked to heating the house from a lower overnight temperature as it doesn't trip when the heating periodically comes on to top up the temperature again during the day.
The following items are on the affected RCD circuit - TV, Sky box, hi-fi, various floor lamps, phone, alarm, shredder, laptop (when charging), phone booster, outside light, PC, printer, router, radio. It doesn't trip if I disconnect all of them (which perhaps suggests that it isn't caused by a cable touching a hot pipe), but I can't identify which, if any, item is causing the problem. Any combination of items connected results in a trip.
Hi - you mentioned that it doesn’t trip in summer ... does that mean you had the same issue last winter, but it didn’t happen last last summer. Or does it mean this is a new problem that has just started to happen?
Also, how is your hot water heated please?
Thermal movement causing the fault to come and go is not contrary to your observation that unplugging the loads stops the tripping, if it is a neutral-earth fault. These often manifest as circuits that only trip under load, even when the loads themselves are not faulty. N-E faults can be influenced by loads on other circuits, so the time of day and season might affect the tripping threshold if circuits on the other RCD are more heavily used at certain times. However, it will always be the RCD that protects the faulty circuit that trips.
ok firstly is this a combi boiler or a system boiler? have you got a big green water tank or white one? if you turn you hot tap on does the boiler fire up and give you hot water?, do you have solar panels and a Immersun?
The problem was there last winter too, although not as bad. No problems over the summer until we turned on the c/h.
We have an oil-fired Worcester Greenstar Camray condensing boiler. It is a fully pumped system with two motorised valves, one to the rads and the other to the coil in the h/w cylinder. In the summer we use the immersion heater, and turn off the boiler. We have PV panels and they help heat the hot water via an iBoost unit which diverts power to the immersion heater if we're not using the all electricity being generated.
Reply to RCD tripped by central heating which is on a separate circuit in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
