SIMBO
Has anyone come across surge protection devices being the source of an RCD trip at consumer unit ?
Discuss RCD Tripping and Surge protection devices in the Australia area at ElectriciansForums.net
Surge protection devices do trip RCDs as they regulate transient voltages and RCDs are voltage sensative.
The class I SPD device is normally the one fitted at the origin of the installtion and is for protection against direct lightning strikes.
Class II are normally at sub board level and used for transient voltage surges on indirect lightning strikes, motors flourescent fittings, and equipment that have transient switching loads.
Class III are the very local ones used at individual pieces of equipment or on extension leads.
Most installtions that require SPD use a combination of devices and they are mostly class I and II which would be upstram of RCD protection.
Unfortunately what happens with the class III in the UK is when you get brown outs, or even switching on the distribution network it will cause the SPD to intiate and of course it will unbalance the RCD causing it to trip
Malcolm,
No SPD will protect against a direct strike, they are not designed to protect against direct strikes, even origin spurge protective devices are only designed to protect against man made and naturally induced transients to a level well below the energy of a direct strike.
HTH.
What is a "brown out"?
Reply to RCD Tripping and Surge protection devices in the Australia area at ElectriciansForums.net
