Rcd tripping on downlights | Page 3 | on ElectriciansForums
Discuss Rcd tripping on downlights in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Been called into a job,electrician who started to find the fault,left & said he couldn’t find the fault,leaving the client running extension leads everywhere for lights,even in the bathroom.
Basically for what ever reason the rcbo trips ,it can be reset but trips again.
It’s a bungalow with joint boxes for the lights,& loads of fibreglass.Ive split the circuit so now half of the lights are on,but kitchen & diner are off.
The M ohm resistance of the faulty cable is L - E,N - E 0.09,L- N 6.90,
No idea why this cable is at fault,managed to get to all lights,they seem ok,not ideally terminated but looks ok.
Later today will try & get to switches & megger as I go along,the baffling thing,is that this fault is happening ,it a nightmare.
Lightweight:D
I am qualified level 3 with NICEIC
Trouble is people need to understand that RCD trips under an imbalance in the circuit for example some touching a live conductor.
But MCB'S trip under short circuit or overload
I guess the water conductivity acts as a bridge between the live and either neutral and earth.
Too many sparkies jump straight to testing rather than inspection first and even isolating the problem by visualising.
Yes I am a lightweight one bottle of wine and I'm knackered lol. Have a good boxing day
You to
Reply to Rcd tripping on downlights in the UK Electrical Forum area at ElectriciansForums.net
Thank you for taking the time to help explain this - much appreciated
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
