RCD tripping on "No Trip" Zs test | on ElectriciansForums
Discuss RCD tripping on "No Trip" Zs test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
Geoffers
Hi folks,
changed a CU over yesterday to a dual RCD board. Standard affair, all tests fine. Did live tests, started doing the Zs for the lights. Both up and downstairs lights kept tripping the RCDs. I'm using my Megger with the 3 leads to avoid tripping. Megger was set to No Trip Loop and all that. Zs for all other circuits fine
Am i missing something? .......cpc's are all present and correct in all circuits as i thought initially i may not be getting a good earth.
Stumped
are the 2 lighting circuits on the same RCD, or 1` on each? is there the possibility of there being some leakage existing, so that the Zs test current takes it over the threshold? do a ramp test on the RCDs.
lighting circuits are on different RCD's ....good idea re ramp test
Did you try testing the RCD's to establish if they are goosed or not???
Unlikely but needs ruling out at least.
yeah, good point but as all other circuits tested fine i ruled this out, bit hasty perhaps....
i'll go back and approach with a fault finding head on ....
thanks all!!
Reply to RCD tripping on "No Trip" Zs test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
Which rcd is it? Is it one for everything, one for a few circuits?
