rcd tripping times | on ElectriciansForums
Discuss rcd tripping times in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Farmelectrics
Wirral
just a quick one doing some rcd tests today, and at x1 value the tripping time was 46mseconds and at x5 29mseconds now i no that as long as at x5 value is under 40mseconds all is ok just thought the x1 value was a bit high so my question is there a max value for times 1 as i must admit not had x1 values that high before your thoughts please
There all the same those switchy things than the wires go in. I only use the ones with 40 on them cause its my favourite number.
but if the wirral was in wales, would there be enough sheep to go round?
would the sheep need the wellies to cross the dee estuary?
Reply to rcd tripping times in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ok I’ll try this when I’m down
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
