mikeyking
Unfortunately my electrician is too busy installing EVs so I've kinda been left on my own for now! I have an issue where the RCD labelled #1 in the attached picture trips as soon as I attempt to turn the immersion heater on. I've had the immersion heater replaced (well, I couldn't get it out of the hot water tank and nor could my plumber so he replaced the tank and immersion heater) but it still trips.
I did have a MyEnergi Eddi installed to divert excess solar to the immersion heater, but I've now taken that out of the equation and the immersion heater is wired directly into the correct switch. The heating system will run fine, pump etc. off the same circuit but as soon as I turn the immersion switch on the RCD trips.
I've replaced the switch, checked all the connections and can't see any issue. Does this seem like a neutral leak somewhere? How can I find out where that is?
Any advice would be appreciated and not legally binding
- TL;DR
- RCD trips on turning on immersion heater - is it a neutral leak?
