RCD tripping - why? | on ElectriciansForums
Discuss RCD tripping - why? in the Australia area at ElectriciansForums.net
M
mike-evans
Hi all. Over the weekend I've had a strange electrical fault bugging me..
The washing Machine is tripping out the RCD, no other breakers..also the oven does the same, trips RCD but no other breaker???
Me and my father in law (he's a qualified Elecy) done a little digging on it last night, disconnected the Heating element in the WM and run it, and it run fine (seems ok as it's not heating the element)...
Then I turned the oven on (with WM running with Element disconnected) and it tripped the RCD...
If I unplug the WM and turn on the oven, it will trip..
If I turn the WM on and let it run for a minute or so, it's fine until it starts to warm the Heating element..
I find it a massive coincidence that both appliances that have independant circuits both have faults?
I'm thinking the RCD is at fault, as it protecst both of the circuits?
Can anyone shed some light on this?
House electrics are just over 5 years old, with no issues at all until now..
1 Faulty RCD, so if you FiL is a sparks get him to do a ramp test
2 Accumulation of protection conductor currents (FiL) will know this being a sparky so clamp test the circuits with a clamp meter that will give you this reading
3. Elements breaking down on both the W/M and oven get the FiL to carry out an Insulation Resistance test on both appliances
I'm not a sparkie, just got a slight understanding of electrics, so I'm not touching anything :shades_smile:
FIL just had a meter with him last night, checked the WM element and was ok, just 1 reading slightly lower than the others, but it's not screaming out faulty...??
no offence but if your f.i.l is a spark it should be an easy fix and he will know when a washing machine heating eliment goes (usually a burnt out hole) the chassis could become live.
As said get him to do (which he will know) ir & ramp/half current tests and go from there ! if the heating element tested ok why replace it ?
Exactly...
I dont want to replace parts as a trial and error process, because that could cost loads, I just want to nail the fault..
I'm just asking for views on here, are 5 year old RCD's known to be faulty at this age? at any age?
I'm finding it hard to beleive 2 appliances have established faults on the same day....
So, how does this sound to the experts?
Is it possible that anoth of my appliances etc...has a slight leakage and then by switching on the WM or Oven will take it up over the 20mA to trip the RCD?
I'm gonna unplug every appliance tonight and just plug in the WM and try it, then unplug the WM and try the oven...
Elements leak more current to earth as they get hot. If you test when cold you may find it's OK, but leaking may occur when at running temp.
With the element removed, connect up the IR leads and set to constant test. heat the element by moving a blowlamp along the element until it glows dark red. When you hit the position of the fault the IR will drop like a stone. It is quite possible that both elements are faulty.
Ive unplugged everything and tried the oven, and it trips...
Everything unplugged tried WM and it trips...
Im just doing basic tests as havent got any testers etc...here.
So surely this says both appliances at fault or RCD....
there's also the possibility of a N-E reversal on the circuit. if f-i-l knows what he's doing, ne should have solved it by now. if not, then it's time to get on the dog&bone.
Reply to RCD tripping - why? in the Australia area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
