RCD tripping | Page 2 | on ElectriciansForums
Discuss RCD tripping in the UK Electrical Forum area at ElectriciansForums.net
A
abdulrahman42
Hi All,
I am a little bit confused, I have just bought a house and the boiler and whirlpool bath are connected together to a 16amp breaker, I know the boiler should have its own supply but this is what I got.
Anyway if the boiler or whirpool is turned on, it trips the RCD. Ive disconnected the boiler and turned the whirpool on and vice versa but still the RCD trips. Ive checked the resistance on the appliances and both are good but they are old and my metre might not be great.
Ive put the supply to a 32 amp breaker just to see if the RCD trips however it doesn't and both work. Im confused about the fact that if there was an earth leakage fault I assumed it would still trip the RCD even on a 32 Amp breaker.
Am I missing anything as I'm not sure what to do next. Please Help.
Regards.
Can I just chuck my thoughts in here, it says in your profile that you are a trainee electrician. Obviously, from your posts, you are very unsure of what you are about, so why don't you talk to whoever your trainer/mentor is? can we assume from your nick that you are 42? If so, how are you training?
Reply to RCD tripping in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
