RCD tripping | Page 2 | on ElectriciansForums
Discuss RCD tripping in the UK Electrical Forum area at ElectriciansForums.net
United Kingdom
Hi everyone,
I started to use my chop saw on the down stairs ring main an it instantly tripped the RCD on the board. I tried different sockets and the same thing happened. Tried it on the upstairs ring and it worked fine.
So I turned off my tumble dryer off and then used the chop saw down stairs and it worked fine. The dryer runs fine otherwise.
Would this be an overload fault? It's and 80A RCD and all I have turned on for it to trip is the fridge/freezer, tumble dryer, security cameras, WiFi router and chop saw.
I've never had this issue before and nothing has changed, it's just started randomly.
Thanks.
Reply to RCD tripping in the UK Electrical Forum area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
