RCD Tripping | on ElectriciansForums
Discuss RCD Tripping in the Australia area at ElectriciansForums.net
W
willy.d
Help needed please!
RCD supplying three ring final circuits. Everything unpluged, turned off etc. Reset all MCB's and RCD. Then, on any of the circuits apply a load (different loads, kettle, tv etc) and the RCD trips?
This is an existing install working fine untill now. I'm thinking the RCD is defective?. Only had an hour there for a quick poke around and back tomorrow with my megger for a closer look but some pointers would be very welcome!
Thank you
Thank you.
No, nothing installed, called by the client because of the fault. There have been no problems with the existing installation up to now at all (so they tell me anyway)
I think you will probably find that the RCD is faulty, when you ramp it it will probably top out at less than 15mA, i doubt that its a particular item of leakage as shutting the circuits down would have shown a difference
Willy.
I would suspect a low IR between neutral and earth. Plugging in an appliance load would then cause leakage down the earth. No load =no leakage and that's probably why the RCD does not trip off-load.
Typical common causes are compression of cables in accessory back boxes, Cables trapped behind accessory fixing screws, Waterlogged jointbox under sub-floors, Fixings for pictures, shelves etc in walls above sockets, cables crushed in joist notches under floor boards, cables melted on heating pipes, Waterlogged outside lights fed from single pole switched spur connection units, Damp garage or outside wiring accessories.
One of my most disgusting causes was a semi-decomposed, half cooked mouse stuck in a joist hole after electrocuting itself knawing through PVC insulation.
Changed a light fitting the other day. Mob off and tested no power. Next thing rcd trips and takes out computers.
Problem was I touched neutral and earth at same time so rcd saw a leakage. Pain in the but and embarrassing when told the customer he could carry on working, fortunately I told him to save his work just in case.
Willy I was called to a very similar fault a few weeks ago and after asking all the usual questions I.e have you hung any pictures, had any work done, drilled any Walls I was told no, I explained that RCD's don't tend to suddenly go faulty in my experience and it's possibly something like an old appliance gone faulty I.e cooker. I got there, investigated and ate my words the rcd had indeed gone faulty! I was able to easily verify this before buying a new one as it was a dual RCD split load board so I swapped the RCD's round.
Anyway if your sure everything is unplugged (don't forget hidden treasures and spurs off the ring like boiler spur, extractor hood etc) then prob best to try replacing the RCD. if the new one trips then it's almost definatly a neutral-earth fault. Then
It's a case if finding out which circuit the fault is on, then when you've narrowed it down to a circuit you can investigate that circuit to find what's causing it. Switch/socket being screwed back and one of the pins damaging a neutral cable is a common one. This is more common in single boxes as obviously there's less room in there = more chance of a cable sitting behind a pin. Hope this helps don't forget to let us know how you get on!
Remembering how the thread started
Because the fault manifests its self on any of the 3 circuits, it most likely will be the RCD. If not, I cannot imagine the scenario which would involve those three ring circuits.
Reply to RCD Tripping in the Australia area at ElectriciansForums.net
I e got a guy coming out tomorrow to do some proper testing, it's just driving me insane 🤣 At the moment it's probably got no more than 2kw...
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
