colshaws
Hi All
Called in to see a friend today and was asked to check out an rcd fault. The house has a 16th edition board with kitchen, downstairs and upstairs sockets on the rcd side,all on 3 seperate 32A mcb's. He regularly has the rcd trip out which resets straight away and then trips out about 11/12 hours later, by disconecting appliances he has narrowed it down to a socket feeding a fridge freezer in the kitchen/diner.There are 2 sockets in the kitchen/diner that are on the downstairs ring ( not kitchen) on one socket he has an american style fridge freezer, on the other the the offending fridge freezer, or so I thought. If he plugs the offending fridge into the same socket as the american fridge freezer the rcd will trip after the 11/12 hours but if he plugs the offending fridge into a socket in the hall which is on the same ring via an extension lead the rcd does not trip (been ok like this for over a month). I have ramp tested rcd, checked I.R and R1-R2 on circuit and all good. I dont have an earth leakage clampmeter to test appliance but I dont understand why it trips if direct into socket but not if plugged into extension lead to a different socket on same ring. THe socket supplying the fridge has been replaced and I checked the wiring to make sure all was ok. Any ideas
