damartin
Property suffers from high number of voltage anomalies - all traced back to high voltage faults by EDF. Problem is that the RCD (80A 30ma) trips on most of these. Mega gives 2M across the circuit. RCD has been replaced as a precaution but same issue. What could the possible problem be? - have others had this issue? Should I be looking into time delayed RCD as a replacement or is this clearly some device fault within the property? Any advice would be welcome because I have been pulling my hair out over this one. Trips do not happen with enough regularity to remove devices from the sockets to rule equipment in or out - sometimes there will be 3 trips a week - then nothing for months.
