RCD trips to fast on test | on ElectriciansForums
Discuss RCD trips to fast on test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bgec
Hay
I cant do an RCD test
When i press the test button the rcd trips before i can get a reading ??
I have tested with it on other jobs since with no issues. I will change the batteries just in case thanks cbw. 5x and 1x
my dilog gives a blank screen and just beeps at me then say M Ohm!! when batteries are low as its **** and i change them every bloody 3 weeks!!
Is it on "soft" test thats if it has that option?
is it a loop test? because an earth loop impedeance test will cause RCD to trip
could well be a "cooked" rcd - ramp test it and also check your tester on another rcd. A megger 1552 will show "TRP" if the rcd is faulty and not behaving. Have seen this when the load from the mcbs well exceeds the max cabability of the rcd.
What make testers have you got? My megger mft seems to get through them fairly quick, although have started turning them off between tests lately and this seems to help.
Hay
Ah! You are not doing what I think you are doing are you?!
The "TEST" button on the RCD is for manual mechanical testing only - you do not press this when carrying out the X1 and X5 tests with your meter.
Reply to RCD trips to fast on test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
If it’s rcbo’s, then it’s 30mA per circuit… an rcd mainswitch is 30mA for ALL circuits It may just be a cumulative earth leakage which was just...
