RCD Trips | on ElectriciansForums
Discuss RCD Trips in the UK Electrical Forum area at ElectriciansForums.net
Bristol
Hello,
I'm not an electrician. My RCD at home constantly trips. I tried turning off the power, resetting the RCD and putting the circuits back one by one, to work out what was tripping it. All were okay, except when I turned back on 'downstairs sockets' or 'upstairs sockets' either one of those would immediately cause the RCD to trip. I figured it may be a faulty appliance so went round and unplugged everything. However this made no difference. I thought it might be the fridge but I turned off the isolator and my electrician told me it couldn't be the fridge as it's behind a double pole isolator. My electrician is on holiday so won't be able to look for a few days. Is there anything else you think it could be or anything else I can easily check ? I don't have a multimeter or anything. Appreciate any help or advice you can give.
It's a bit needle in a haystack time...
General rule of thumb is that RCD's trip for 1 of 3 reasons:
1. Faulty appliance
2. Damage to a circuit
3. Water ingress.
Reply to RCD Trips in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
Ok I’ll try this when I’m down
As you said in #9 get an electrician involved. The information you are giving is not clear as you do not understand what is being asked which...
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
