RCD wont stay in. | on ElectriciansForums
Discuss RCD wont stay in. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
wing nut
Can anybody tell me if I'am doing anything wrong.
I have a Metrel 3100 multifunction tester. Im trying to do a ze on a tt system.
There is 2 boards, 1 2-way and 1 8-way. Both protected by a 30ma rcd. Used as main switch for both boards.
I have isolated both boards and removed the main earth from a seperate earth terminal which goes out to the rod.
I have my tester on no trip and use a 3 lead test.
But everytime I go to test (the 8-way board) the rcd trips.
Any ideas will be greatfully received.
all wrong, mate.
1. isolate CU.
2. disconnect main earth cable from the CU (or separate MET if fitted)
3. set tester to hi. (not no trip).
4. connect tester between the LIVE at the top of the mainsw/rcd, and the earth lead which is still connected to the rod.
N.B. remember safe working practice.connect live on last and live off first
Everything is off before removing earthing conductor. The rcd is also the main switch. So when turned back on to do test it trips when the test is being carried out.
Reply to RCD wont stay in. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks everyone for your help on this one, I've bookmarked the other thread. Turns out on this one it was a faulty RCD, I went back with a new...
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
