Rcd x5 higher than x1 reading | on ElectriciansForums
Discuss Rcd x5 higher than x1 reading in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
Johnboy78
Hi all, just filling out some paperwork from an inspection a couple of weeks ago and just noticed that a x5 reading is 76.4 and x1 is 28.4-not sure if I've misplaced a decimal point or what.. Going to go back and recheck it tomorrow- how can x5 be higher?
Done a few hager boards recently and all the 5x readings on the RCBO's have been higher than the 1x. Although if your 5x is 89.4 it's a fail anyway.
Reply to Rcd x5 higher than x1 reading in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
That is very cool. It would be the end user software that would make that the absolute king.
    • Winner
    • Informative
