rcd x5 testing trouble | on ElectriciansForums
Discuss rcd x5 testing trouble in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
thomasno1cat
i have been testing an rcd with my calibrated tester but when i test the rcd on x5 my meter shows an error message stating that the fault voltage is greater than 50v. I thought it might be my meter so tryed another and it worked fine. I am now wondering if his meter is faulty.Any ideas?
Reply to rcd x5 testing trouble in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
