Discuss rcd in the Talk Electrician area at ElectriciansForums.net
Hold on folks. First consider these questions:
What type of earthing arrangement exists TNCS, TT or PME....Are they not one and the same....
How far is the outbuilding from the house? - Does it share the same concrete base as the house? is it across a yard or field ?
Exporting TNCS earths are dangerous and should be TT configured at point of use, in this case this may be the outbuilding.
Exporting TNCS earths are dangerous and should be TT configured at point of use, in this case this may be the outbuilding. Not always.
dependant on distance from the house in this case, which you still don't know.
If your comfortable running a large run from a tncs supply to an outbuilding and exporting the earth instead of utilising a tt system at the end of the circuit, thats your perogative and risk assessment
Which ever way you dress it up advice has been given with out first confirming the type of earthing arrangement and after that what exactly the building is and how far from the initial installation it is.
Hang on a minute.......all the OP asked was would an RCD at a house CU cover sub-circuits in an outbuilding if the sub-main was fed from it. You're the one who elaborated beyond the initial question for whatever reason.
All I am saying is how do you know the installation was installed correctly . Your assuming that what was there is or was correctly installed. It may not be, so simply telling the OP he does'nt need rcd protection as it's in his main board is potentially putting him at risk as the installation may require an rcd and tt arangement at his outbuilding if it had not been initially constructed with one.
Don't be too precious I am entitled to my opinion as you are yours.I was only trying to give a wider view, nothing more.
Reply to rcd in the Talk Electrician area at ElectriciansForums.net
