Rcd | on ElectriciansForums
Discuss Rcd in the Australia area at ElectriciansForums.net
T
tijinks
What is the maximum time delay that can be set on a earth leakage device, for a tt system, earth rod not installed as yet, would time delay affect the level of ze that need to be achived???
Reply to Rcd in the Australia area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
