R
Reg Man
Just wondered what everyones thoughts were on this hyperthetical situation which has been bugging me:
If you were to install a ring circuit in a new extension using T+E in 20mm pvc conduit buried in wall 30mm deep etc. The house has a TNS supply, a Wylex fuseboard with cartridge type fuses with no RCDs at all and everything else in the build is in a good state.
What do you do about the RCD protection?
Tell customer they must have new RCD/RCD board even though there is nothing wrong or unsafe with current board?
Install 30mA RCD before main switch over whole system thus possibly introducing a nuisance tripping problem?
A sub circuit with small CCU?
Or what?
Its not a catch, the reason I'm asking is because be it whether its a ring circuit, one additional socket or moving a switch, the cost implications for a really minor job to the customer could be drastically different and see at the minute even more so, Joe Public are very wary when it comes to money.
So how have you all been tackling the situation, Or maybe NOT!????
Or what?
