RCDs when to use | on ElectriciansForums
Discuss RCDs when to use in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Wilson12
Trainee
London
Sorry I’m struggling to use the new search to find a old post ...
I need refreshing spoke to a few sparks and they say just put a rcd for everything...
But what are all the 18th edition requirements when to have an rcd?
As a Trainee Wilson, you will find by looking up the info you require, will in turn indent the info in your subconscious far quicker and longer lasting than just asking, not having a dig at you for asking, it's just something life has taught me over the years. Effort turns into better results honestly.
Upvote 0
Hi i don’t have the regs book and I’ve searched online and I’m not finding a straight answer that’s why I then chose here
Upvote 0
As both posts above , but as Pete alluded to I would obtain a copy of BS 7671. This will help you to navigate the regs and lead you other sections which may also be relevant to a particular search.
Money spent on study and required reading will hold you in good stead .
Upvote 0
As Andy says....watch the videos there’s lots out there, Chris kitcher and John ward are some others that explain things clearly....but I’d also get yourself a copy of the 18th edition and then you can reference what they say and start finding your way around the books
Upvote 0
The guys that say just put an RCD on every circuit have a lazy and uninformed attitude I'm afraid.
By the time you’ve covered all luminaries, sockets likely used by things outside, everything in a bathroom..... you may as well rcd every circuit.
Saying that, I was at a house this morning... 6, 7 year old newish build, so 17th Ed. Downstairs lights on RCBO, upstairs on mcb.
Can’t understand why.
Upvote 0
Alterations on down lights this year?
Upvote 0
I don't think so. Split board... right hand side has all rcbo's… mostly downstairs.
Left hand side is only MCB's... upstairs lights and sockets.
I think the developers were still used to installing split boards with 2 x rcd mainswitches and MCB OCPD. Regulations changed and they just cobbled together what they thought they needed.
Upvote 0
I do agree that most circuits end up RCD protected. My point was that just using it as a blanket rule is no substitute for actually knowing the requirements, especially when imparting knowledge and work ethics to a trainee.
Upvote 0
Might just as well use a 61008 RCD as a main switch, there’s a security blanket for you!
Upvote 0
Reply to RCDs when to use in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Best Electrical Courses I endeavour to create a "best electrical courses" thread for 2025 (so training courses that did well during 2024 are the...
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
Electrical Courses
