Rcd's with High Resistance | on ElectriciansForums
Discuss Rcd's with High Resistance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Staffs
Hi, I recently installed a new c/u and was talked into a MCG board by my local wholesalers (which won’t be happening again!!!).
The problem I have is that the rcds are adding 0.51 to my zs reading. It’s a tnc-s system with a 0.04 ze. If I do an r1+r2 on a lighting circuit for example its 0.93 but my zs is 1.44. I have replaced the rcds but still getting the same reading. It is definitely the rcds as I have done a loop test either side of the Rcds there is a difference of 0.51. My question is are these readings acceptable as the zs is still within the limits or do I replace the board? thanks
One thing i will say is never use MCG they are absolute crap. So long as your Zs is below the maximum permissible then leave them in.
TBH Tel I have never used them.
i've used 1. it had 3 decent N bars so was versatile and has a built in spirit level so even i could get it straight. good price as well. ÂŁ65 fully loaded.( 2 RCD+10 MCBs) inc. VAT.
Reply to Rcd's with High Resistance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
