Rcm1 pump wiring | on ElectriciansForums
Discuss Rcm1 pump wiring in the DIY Electrical Advice area at ElectriciansForums.net
B
bart12
Hello, I'm seeking some advice please. I'm swapping a like for like ? Salamander RCM1 pump. As the photos illustrate, the original pump has wired in two separate terminal blocks, one to the pump and one to a fused connector box 12 inches away.
The replacement pump came wired as shown, pre wired for the 240v fused supply. My query is : How should the three cables from the electric side of the pump be wired . Hope this makes sense. Salamander have been of little help. Many thanks in advance .
  • [ElectriciansForums.net] Rcm1 pump wiring
Reply to Rcm1 pump wiring in the DIY Electrical Advice area at ElectriciansForums.net
There are two reasons for a fuse/mcb they are: 1) fault conditions - which must exist always, and be capable of operating for all points on the...
I think that's the point I was trying to illustrate. If volt free contacts on a device on one supply are switching mains voltage coming from...
