sl1210
Hi guys,
Need to quote for a job where the customer wants the consumer unit re-positioned to the other side of the wall its on at the moment. Basically it used to be in a cupboard, but now that cupboard has been joined to the bathroom, and they don't want to box it in the bathroom. Its a flush metal box, but there is a seperate main earth cable coming in, and all circuits have there own earth, not dependent on metal conduit.
I can extend all the circuit cables easel by crimping them, but not too sure what to do about the tails. They are 16mm singles run in metal conduit, and the isolator and meter is in the communal hallway. Whats the best way to extend them, baring in mind it might not be accessible, unless i make a big hole in the wall behind the fusebox??
Pulling new singles in from the meter cupboard is a possibility, but i don't know if i feel too comfortable doing that, incase i pull the old ones out and struggle to get the new through.
Cheers
Cheers
