Re-wire: Best method for wiring lighting? | on ElectriciansForums
Discuss Re-wire: Best method for wiring lighting? in the Australia area at ElectriciansForums.net
Reply to Re-wire: Best method for wiring lighting? in the Australia area at ElectriciansForums.net
Hi again, "trying to save money" doesn't really come into it. We parted company with the original sparky, as he was so unreliable. Jon
Agree with SJD. Also the 2.4V you have from the 2 cells may not be enough, but worth a try.
It could be a slave switch where you would have a L in and a common wire out to a master switch.
Not totally clear what cables are accesible in the loft, but ... Can you not just feed a permanent L & N from the switch to each of lights 2 and...
Thank you Thank you all done and working
