Re-wire | on ElectriciansForums
Discuss Re-wire in the Electrical Course Trainees Only area at ElectriciansForums.net
bigash
uk
Doing some rewiring on behalf of an unnamed council.
This is what I found today when removing the lid off of surface mounted trunking.
Has anyone ever seen this before where the insulation is removed to get around corners?
I really dont like the cable going up the side of the door frame inside the arco.
I know this is a no no but found it strange that the circuit would of passed testing as surely an insulation test would of failed. Maybe the wiser ones on here could enlighten me.
I hope the photos have attached spam ad free. [ElectriciansForums.net] Re-wire[ElectriciansForums.net] Re-wire[ElectriciansForums.net] Re-wire[ElectriciansForums.net] Re-wire[ElectriciansForums.net] Re-wire[ElectriciansForums.net] Re-wire
I have just thought about that and yes it may of not showed up on the insulation test.
Its crazy as the damaged cable was in the same room as the main fuse board. There was plenty of other surprises that took this two day rewire into a one day rewire. as we could not leave the circuit in the state it was, so overtime in and a very late finish.
The words Hazard came to mind when i discovered it among other things.
The idiot that done the original rewire is really RAF.
I am amazed by what you find in council houses. Today's find was a light pendent attached to an old light pendent that had been hidden between the ceiling and floor boards and an old junction box that to be honest was worse than RAF it was bloody ridiculous.
The main thing I am learning here is how not to do things.
Its stranded mate and 2.5 t & e.
Can't say i have ever seen a harmonised colours 2.5mm2 T&E cable with a stranded CPC! But then again i did a job the other week which was wired in white twin and earth, except the CPC was insulated as well throughout the cable.
First time i have come across this type of cable.
FT&E CPC sizes
1.0mm2 = 1.0mm2 CPC
1.5mm2 = 1.0mm2 CPC
2.5mm2 = 1.5mm2 CPC
4.0mm2 = 1.5mm2 CPC
6.0mm2 = 2.5mm2 CPC
10mm2 = 4.0mm2 CPC
16mm2 = 6.0mm2 CPC
Omg thinking about it neither have I.
Now this is where I backtrack and say maybe I need to get the caliper out and actually measure the cable instead of stating size by eye and a s***e memory.
Also in one of the photos there is a 2.5 t&e in one of the photos.
Reply to Re-wire in the Electrical Course Trainees Only area at ElectriciansForums.net
