H
hman
Hello all.
I'm qualified but not competent. Lacking in experience, a catch 22 as I keep being told by prospective employers over and over again. I need to rewire my kitchen before a new one is fitted and it will be good practice.
The wiring is currently a mess. Lights and sockets on the same one radial. A ring, another lighting radial and a cooker radial all going back to a bs3036 rewireable fuse Cu.
I want to replace it all with 1 lighting radial, 1 cooker radial and an extension of the downstairs ring. Please let me know if my following thinking is correct. As I'm extending an existing non rcd'd ring I don't need to rcd protect it, right? As for the oven, it will be the same cable as it's 6mm already so will I need to rcd that? I'm considering changing the cu but I'm worried about it highlighting other problems as the systems 30+ years old and has been added to by various diy enthusiasts over the years. Spur on spur on spur etc. Are there rcd's available that will fit an old rewirable board? Or can I fit an rcd'd connection behind the oven at the load end of the cable?
All advice appreciated. Thanks.
