M
martysparky
I called at a house today to do a little job.
The clients house had recently had a total rewire he mentioned that a switch cable had been dropped through the floor boards, down the cavity and back through the wall to the switch.
My thought is that cannot be done inside Bs7671 unless simply replacing a cable following its designed route but that would not be the case here.
I guess, however, that would be the reason to replace a cable I.e. rodent damage as they can get in cavities and so can water and subsequently run down the cable to the switch.
What would be the best practice with this one?
Suggestions would be of interest.
Cheers.
Cheers.
