vbyrne
Hello, I have completed a test on a flat ,everything was fine until I got to the RCD test. The set up is T-N-CS ,6 circuits on the main switch side of the board and four on the trip side .I,m using a Fluke tester and have recently got it calibrated ,when I do x1/2 it,s ok ,when I do x1 it reads 246ms , and when I do x5 its ok .I have put 3 square D trips into the board and the readings all come up the same ,so it must be something on the board some where that is causing this high reading , any help lads:whatchutalkingabout:bigcry:
