Hello! I am in the planning stages of a new dwelling construction. The foundation will be a monolithic cement pad with rebar. Based on my research, I am fairly certain that I need to ground the rebar within the slab. The slab will have rigid insulation under it and will have a vapor barrier, so I do not think I can use the rebar in the slab as a ground for my main service, which is fine. My question is, should I bond the rebar to the main ground for the electrical service (that has the ground rods driven), or should I install separate grounding rods for the slab itself. If either option is acceptable, can I get opinions on which option to use? Thanks!
