Discuss rebuild BG consumer unit as mirror in the Talk Electrician area at ElectriciansForums.net
I would say if terminals are specifically marked on Rcd. I wouldn't do it. I believe it can cause issues with internal resistor when test button operated. Can you not extend or renew tails ?
Reply to rebuild BG consumer unit as mirror in the Talk Electrician area at ElectriciansForums.net
