recessed light with 2 marks | on ElectriciansForums
Discuss recessed light with 2 marks in the Lighting Forum area at ElectriciansForums.net
london
Hi,
I don't know how to unscrew these ones...tried different options (screw, push, twist).
any suggestion?
thanks![ElectriciansForums.net] recessed light with 2 marks
The retaining ring with the two lugs 180 degrees apart twists and the lamp then comes out. But sometimes they get jammed, especially if heat damaged after prolonged use with halogen lamps.
As above they can get very stiff to twist over time but with a bit of force usually do twist
If not then your only option is to pull the light down
Righty tighty.. lefty loosey
Make sure you twist it the right way.
The lamp is attached to the central ring that unscrews. As said above, you might just need a little persuasion to get it moving.
If needs must, you can take the whole fitting down, but watch your fingers on the retaining springs.
Reply to recessed light with 2 marks in the Lighting Forum area at ElectriciansForums.net
seen a couple of your posts now and IMO you are trying to save money by doing the design and install yourself even though you have no...
Flange and nuts in the same sentence. Jeez I really must start acting my age.
