Recommend a 2 channel timeclock please | on ElectriciansForums
Discuss Recommend a 2 channel timeclock please in the Central Heating Systems area at ElectriciansForums.net
Hi I have a 2 year old honeywell ST9400C programmer which when you put the hot water and the central heating on (YPlan system) the hot water does not heat up.
Can any one recommend a half decent replacement please.
[h=1][/h]
why do you assume it's the timer have you tested voltages? If you haven't it points more towards the cylinder stat rather than the timer
- - - Updated - - -
Oh but if you have I would replace it it with another Honeywell they are still one of the best
I reccommend another honeywell too if it does need replacing but check your voltages first, honeywell have a good app with all the wiring diagrams in it, very handy!
[/SIZE][/SIZE]
- - - Updated - - -
I googled the ST9400C programmer and lots of people have had problems with it, hence I am in two minds.
Problem is people only tend to put reviews on line when they have bad stories, they must be a really small percentage of clocks installed, I had the unfortunate task of wiring central heating for a couple of years and fitted hundreds of these Honeywell clocks and never really had any problems to be honest. So if I was fitting a clock in my own house it would be a Honeywell
I used the fault finding section from the honeywell book, and replaced the faulty timer with a 'good' timer, also checked the 3 port valve
Reply to Recommend a 2 channel timeclock please in the Central Heating Systems area at ElectriciansForums.net
That's just a standard timer switch. The 2 red wires to the timer are the switch contacts, the 2 blue wires are power to the clock. The 'orange'...
