Recommend a IP65 consumer unit please. | on ElectriciansForums
Discuss Recommend a IP65 consumer unit please. in the UK Electrical Forum area at ElectriciansForums.net
1Justin
Surrey
Could someone recommend me a 7 unit wide (minimum) IP65 consumer unit? Plastic is OK, - it's for a horticultural site in a polytunnel.
I find Garo, Protek, any others? (Looks like I'll have to populate it anyway with A.N. Other breakers and parts).
I want want robust enough to take several SWA's without problems and reliable door seal.
Plastic and SWA, Hmm not a good mix imo, more trouble than it's worth by not fitting a MC CU as for mixing and matching OCPS best refer to BS 7671 prior to taking that route 1 Justin.
Can't beleive no-ones noticed it's not orientated correctly.
The lamps should be pointing to the 4 corners of the room..
I used the Hager ones (Vector?) in our Polytunnels. I also put it in an external meter cupboard for belt and braces - 2 x 4 year olds and a hose can do serious damage! They take SWA no problem, knock outs on all four sides and back and come with a load of glands.
Thanks guys. I'll take a new look at those Hager and Schneider ones. I have only once or twice used a Hager board. My local Rexel does it - meaning plenty of opportunity for bargaining :)
I have used Merlin Gerin (now Schenider) Kaedra units before. Well manufactured plastic units.
I used to use Kaedra but they were so often out of stock for the larger units..
Then I switched to ABB mistral which are honestly even better, very easy to work with and cheaper too!
Consumer Units | RS Components - https://uk.rs-online.com/web/c/fuses-sockets-circuit-breakers/consumer-units-accessories/consumer-units/?applied-dimensions=4294967273,4291943652
They are far and away the best I have found :)
Thanks Deuce. the enclosures look sound.
They really are good, so much space to work in them!
Make sure to feed back on here if you order one - although I'm pretty sure you'll be very happy if you do. I work exclusively in wet environments so I've been through a fair few such products over the years ;)
Reply to Recommend a IP65 consumer unit please. in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
  • Solved
Therein lies the problem. I see no merit in further circular debate, so will bow out of this discussion.
7K
nicebutdim
N
Morning all Thanks for all your inputs this has been very helpful. Things are clear to me now and i am happy that i don't have to make any...
23K
Lost me @richy3333 sorry mate ?
7K
I’ve been installed Lewden RCBO for years with only 1 RCBO failure. I’ve fitted lots of their 19 way boards too. I recently installed a 10 way...
21K
B
Luxury I got 45 + years of working. Tell the kids of today, especially those noise brats next door, whose parents are away, and are pi$$ing it up...
4K
