H
Hawk
Hi guys,
Here is the set up in a shop:
Three phase supply from the supply meter into escos. From the escos there is tails going to a 100A isolator which supplys a board upstairs and a set of tails supplying a 100A 100mA RCD. From the RCD into a distribution board downstairs. From this distribution board there is a cable supplying another board from a 63A Type C MCB.
The problem is that one of the machines in the shop tripped off during a cycle. It first took out a 40A MCB supplying it. I checked out the motor, compressor etc in the machine which were all sound. When turned back on it ran for a few hours and then took out the 63A MCB supplying the board. Im thinking that it is overloaded as there is four freezers, a cooker, four machines which have a total rating of around 62 A aswell as lights sockets off this board. It's funny thou because the shop was a new installation about three years ago and there has not been any previous problem. The owner says that there has not been any new equipment.
The system is a TT system.
I was thinking of getting another 100A isolator to supply the distribution board and doing away with the 63A MCB.
What would you recommend? Also why would the electrician who wired it have used a 100A 100mA RCD instead of A 100A 30mA?
