E
electek
Hi All ,
Can anyone give me any advise on reconnecting a star / delta motor which was disconnected by someone else and the 6 wires were not labelled !
I understand the way star delta works and how it changes over e.t.c. e.t.c. but i've heard about in some cases motors running ok in star but tripping when swapping into delta cause they are incorrectley connected ??....
Also will the motor be rewound exactly as it 'came off' so that if the person had made a note of the connections it would be a case of simply reconnecting or is it possible that a rewind company could make any changes to the windings which would affect the running after reconnection.
I find the whole star / delta issue a bit confusing , can anyone explain the best way of ensuring all is correct ? Any help much appreciated.
Many Thanks
Many Thanks
