Recording studio. Supply. | on ElectriciansForums
Discuss Recording studio. Supply. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
N
Nic Norwood
Currently pricing a Job up for a friend who's recently had a recording studio built at the bottom of his garden (10m from house. 13m from C/U).
Inside Studio is fairly straight forward:
1x 4-way RCD protected C/U
2x 16a Radial (1 performance area, 1 studio area) feeding 5 outlets each. (Nothing major will be drawing current: pc, monitor etc.)
1x 6a Lighting for 2 strip lights and an external recording light.
Spare way for possible alarm system.
Issue is the C/U in the house, whilst there is a spare way, it's an old square d board and I can't imagine I'll be able to get a new MCB to fit. Was looking at a henly block, but then would I have to bring the new C/U from the studio back into the house?
You could install a small enclosure with a main switch and a single MCB.
Something similar to a shower or garage CU, but with a main switch rather than an RCD.
So Tails -> Henly block -> 1st Out -> House C/U ->Final Circuits
2nd Out -> 1 Way main switch w/45a MCB -> Studio C/U
I'd watch those 'strip lights' for any hum and crackle in a recording environment.
most wholesalers will get to order. last year i managed to get a 3 phase one through electric center. cost ÂŁ80 mind.
Reply to Recording studio. Supply. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Your kWh figures are giving you consumption averaged over each hour period, but don't give an indication of total instantaneous current. To try...
