ringer
What do you do when you come across small faults or non-compliances during a PIR? Some things are so easy to remedy it's a bit of a no-brainer to just fix it on the spot. But then how do you get across to the customer that, by having an inspection done, you have made the insallation safer? Because if you don't say anything they won't realise the full benefit of employing your services. And because you have remedied the problem, there is nothing to record on the cert!
