Hi all. hope someone can point me in the right direction.doing a rewire for two flats above a shop which is straight forward enough. except the mains are being moved from the front of the shop to the rear. the dno want three switched fused isolaters installing at the rear and a 115mm red ducting installed in the basement about 450mm from the basement ceiling for the new mains cable to run in. whats the best way to mount the duct.only had experience in ducting in the ground.is there any special brackets that someone could point out to me?the distance is about 12 meters. as the mains are being moved to the back and the shop consumer unit is about 12 meteres away at the front is it ok to run 25mm tails on say a cable tray from one of the switched isolaters back to the front of the shop. i assume swa would be best but its a insulated consumer unit and room is tight to swap back to a adaptable box.the specified switch fuses are 80a for the shop and 60a for the flats and is a tn-s system.
many thanks in advance...
Daz...
Daz...
