Hi guys what do you think of this. There’s been a temporary bit of plant wired up out of an existing circuit which is an 100amp supply I believe. The circuit then goes through a soft start to a local isolator about 50meters away. The motor is supplied with 10mm flex but due to the flex not being long enough someone has used a JB and extended to the isolator with 6mm flex. My thoughts are the 6mm is a bit close as the motors FLC is 41 Amp. I’m also aware the main fuses are 100amp so again oversized. Another question was the overload was set to 41 amps I know this isn’t ideal to rely on but would the cable be protected?
thanks guys
thanks guys
