Reduced neutrals | on ElectriciansForums
Discuss Reduced neutrals in the Electrician Talk | All Countries area at ElectriciansForums.net
R
ryanryan
On a PILSC SWA cable with a reduced neutral, I would assume that the fuses should be selected to suit the design current for N?
any suggestions?
you would have to assume that,you would have to check with cable manufacturers tech. dept. ie.bicc /aei / enfield standard ect.
yours benji
Reply to Reduced neutrals in the Electrician Talk | All Countries area at ElectriciansForums.net
Noted. Thank you. Out of phase summation being the answer to the question.
I do not think so, rather someone has seen that this cable is cheaper than what was ordered and thought to save some money. Yes Steel Tape needs...
Did a fuseboard change yesterday from an old wylex board to dual rcd on a TT system with 14ohms ZE and finished pretty late. Went back this...
Any chance of a photograph? What you’re describing seems straight forward. Just because a wire is black, doesn’t instantly mean it’s a neutral...
