Refence method, disagree meant on a job | on ElectriciansForums
Discuss Refence method, disagree meant on a job in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
Jimmyb
hello, What ref method would you class this cable there will be 100mm of king span to put in but the cable will be above the king span by 10mm or more so not in contact with any insulation.
thanks
[ElectriciansForums.net] Refence method, disagree meant on a job
sorry 101 is insuylation not exceeding 100mm. 100 is what i shouls have said for no insulation above
just got on site guide out and 101 is insulation exceeding 100mm, 100 is insulation not exceeding 100mm, and c is clipped direct.
are u saying it's clipped direct or insulation not exceeding 100mm
thanks
kitchen (extension) radial, builder's sparky reckon it method 100 so will have to be made in ring which is sort of problem cos bathroom floor has been tiled now so hard (impossible) to get a another cable though but could use shed cable as its also 4mm and run new cable outside for shed but i was sure its classed as clipped direct and didnt want a cable on outside of building if possible.
just woke up. re-read post correctly. cable is not covered by any insulation, so therefore its method C , clipped direct.
farm job yesterday, all ladder work and dodging fork-lift trucks driven by farmers. fell asleep after 3rd pint
Reply to Refence method, disagree meant on a job in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
