Mr.Si
Hi all,
It's a lovely day outside, the sun is out and the sky is blue, so naturally, I've been cleaning the house all day and am now reading my Regs looking forward to the point for when I re-wire my house room by room, once I have the relevant experience and quals etc.
I'll be doing it by chasing the cables into the external masonry walls as much as possible and so I was brushing up on the different reference methods and Table 4D5 for the CCC of Twin & CPC.
However, I could only find the following reference methods:
100# - Above Plasterboard Ceiling with <= 100mm of Thermal insulation
101# - Above Plasterboard Ceiling with >= 100mm of Thermal insulation
102# - In a stud wall with thermal insulation, where cable touching inner wall
103# - In a stud wall with thermal insulation, where cable NOT touching inner wall
C - Clipped Direct
A - Enclosed in Conduit in Insulating Wall
Now, is it me or do none of these methods cater for my chosen installation method?
or
Would it be A, as it'd kinda be an insulating wall (due to having a cavity) and being behind Capping?
I look forward to your responses as I'm not fully sure.
Thanks,
Simon
C - Clipped Direct
or
Thanks,
Simon
