Reference method | on ElectriciansForums
Discuss Reference method in the UK Electrical Forum area at ElectriciansForums.net
R
Rob Smith 643
Reference method for running an RFC through plastic trunking (B?) and does a grouping factor apply, i.e. is it one circuit or two cables?
Is my copy of the regs any different to yours? I wouldn't have posted the thread if I'd been 100% sure. I'm not into wasting people's nano seconds of time so if you can't be helpful/courteous don't bother, senior member or not. I value the views and opinions of those better versed than I. That's what forums are for otherwise take it off the web mother superior.
Anyone got a helpful response?
Thanks folks for the reassurance. You've confirmed my thoughts re ref method B. it was more the grouping factor that I was concerned about. Now that I've re read osg/ regs I'm happy enough. Whereas I am not keen on t&cpc in mini trunking it's the most practical solution for the job in this case as its just for vertical drops on an install that would otherwise be ref meth C. Cheers. :grouphug:
Reply to Reference method in the UK Electrical Forum area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Thanks for your time and opinion.
