reference methods | on ElectriciansForums
Discuss reference methods in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
Benjamiin
Hi chaps, wondered if anyone had some printable reference method tables I could use for my testing file, easier than attempting to photocopy from the bgb! Cheers Ben
In the absence of any replies, then i guess you are going to be photocopying. I believe that places like staples, will cut the binding off your regs book, and put it in a ring binder, this will make it a bit easier for you.
Cheers..............Howard
Reply to reference methods in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
It’s difficult to advise on an electrical issue when some isn’t very conversant with electrical terminology.
