reg refresher | on ElectriciansForums
Discuss reg refresher in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rwood1981
Hi Can anyone confirm what the regs say about socket distances from sink and hob? from memory I have a metre away from centre i my head is this correct?
Theres no reg just guidance for distance from sink and as long as it not over a cooker i dont think there is any set distance from a cooker
You may also wish to consider
IP ratings, or think about the environment and use a suitably rated socket/switch dependent on how wet it might get. Or put another way, make sure the standard socket/switch is far enough away that it's IP rating is correct. Thanks.
Reply to reg refresher in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A lot will depend on the load on the tray / basket / trunking and the span before it bends / distorts
Hi Steve. Thank you for this, sorry, i should have searched the forum before posting.
