R
Rajan Shakti
can anyone help me with earthing and grounding of cable tray with separate instrument and power
Discuss regarding cable tray layout in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
can you see my one latest post and help me for the same and comment on that
It depends on where it comes from Malc. If it introduces a potential into the installation, then it must be bonded as it is extraneous, but of not then it is an exposed conductive part, and doesn't have to be bonded.
The 23kOhm test can be used to confirm if it requires bonding. In an industrial situation I think it is good practice to bond all metallic containment, as further work by other trades may change metalwork from exposed conductive parts to extraneous. This isn't as likely in a domestic or small commercial situation.
Reply to regarding cable tray layout in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
