regs book help need a table ref no | on ElectriciansForums
Discuss regs book help need a table ref no in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bobby101
hi all just a quikie what table do i refer to in the bgb for checking cable ratings for a concentric cable ?
cheers and beers
Reply to regs book help need a table ref no in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
