Regs on disused cables in DBs | on ElectriciansForums
Discuss Regs on disused cables in DBs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
Bazultra
Can anyone tell me where the regs are in the BS7671 on disused cables in DBs. I know that they should be labelled, dated and grounded to earth but just want to read what the regs say about this.
Thanks Baz
Regs book help please
Can anyone tell me where the regs are in the BS7671 on disused cables in DBs. I know that they should be labelled, dated and grounded to earth but just want to read what the regs say about this. Perhaps this info is in the GN3?
Thanks Baz
I was told you shouldnt leave unused cables in connectors or loose in a DB. That they should now be labelled, dated and grounded to the MET for obvious safety reasons. Sounds like good practice to me but I just cant find where it is in the regs book
Reply to Regs on disused cables in DBs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sounds like a Standard (12kVA) supply then. So minimum of 10mm^2 Earthing Conductor and Main Equipotential Bonding Conductors.
Hi All, In need of some advice on what is and isn't allowed under regs. I'm extending a circuit in my house so I can install a socket on the...
